on drive only from 2-3 shift it falls flat at 6200rpm 75mph and goes to limp mode. if i manual shift around 5500rpm it wont go into limp mode.
can someone guide me in the right direction here? is it shift points i need to change lower?
#46854 max torque limit, #5722 tcm rpm limt, #46956 max torque limit during slip...I'm betting from your log that you are hitting rpm limit... log says around 6380rpm...
martin jr stock tune 3.hpt
this is my file if someone can point me in the right direction.
Edit /Navigator use the table numbers I gave you...
