Results 1 to 7 of 7
Thread: DTC Clasification ?
    Apr 2021
    Pompano Beach
    11
    DTC Clasification ?
    Anyone have the Fault Class ?
    Type 1
    Type 2
    etc
    etc
    Thanks in advance
    Advanced Tuner outlaw_50's Avatar
    Nov 2020
    United Arab Emirates, AlAin
    204
    Quote Originally Posted by tuneitfast View Post
    Type 1
    Type 2
    etc
    etc
    Thanks in advance
    use Type 6 to remove MIL light
    Xstages Motorsport
    Tuning inquiries:
    ECU, TCU, CPC Online Tuning
    Whatsapp: +971503383340
    Email: [email protected]
    Insta: @xstages.motorsport
    www.xstages.com
    Apr 2021
    Pompano Beach
    11
    Thank you
    Apr 2021
    MD
    51
    Disabled is on. Normal
    Type 3 is permanent set code
    Type 6 is off.
    i have same question for vag with MED9
    dtc's have status: disabled, type 1, type 2 and etc
    ...to type 8
    who can explain what these types of class's mean?
    GM FORD DODGE
    custom xdf for hpt
    ...will answer myself
    just checked
    type 8 7 6 5 and disable - no errors
    type 1 2 3 4 - pending errors
    GM FORD DODGE
    custom xdf for hpt
    Jan 2022
    Southern California
    363
    A lot of codes I can't clear with HP Tuners, or a cheap dongle and app. I have to break out Autel or Xentry and this takes 15 min or more. I get them all the time so it's very annoying.
    I don't need to block codes from being recorded, I just want to be able to clear them with HP. So if I set Type 3 codes to Type 6 I can use HP to clear them?
    Or does the Type # have nothing to do with being easy or hard to clear?
    clifftoo said:
    "Disabled is on. Normal" ----- So Disabled is not disabled at all, but what is "Normal"? Non-permanent that go away on their own?
    "Type 3 is permanent set code" ----- I assume means it won't go away on its own.
    "Type 6 is off" ----- I get type 6 codes so I guess I don't understand what "Off" means.
    Then svvag2000 says Type 3 is pending, not permanent. So which is it?
    Surely each Type # means something different? 1 2 3 4 cannot all mean the exact same thing, so what are they?
    I googled but can't find any of these Types at all, only the P U etc types.
    '16 E550 Coupe RWD - C207.373 / M278.922 / MED17.7.3 / 722.909
