Originally Posted by
BlackSunshine99
Excellent, thank you so much for the input Kevin!
The Holley 105mm TB actually has an air bleed adjustment screw on it, I had adjusted it before to get the IAC count down to 40-60 (got that from another one of your posts lol) but it must have went back up when I started making changes. Should I stick to opening the throttle blade or use the bleed screw? Awesome! I'm glad to help. I'd open the blade and get it close to the 40-60 range, then you can use the air bleed screw if you need to make any fine-tuning adjustments.
If I need to increase the Frictional Airflow Initial table, what would you suggest, 5%? You may not need to make any adjustments to the Frictional Airflow Initial table after adjusting the TB...but, if you do, you can just add 10% at a time, as needed.
Would it make sense to have the PE and BE tables match or does the ECM need to reference one or the other?....or does the ECM reference PE when not in boost and then BE when boost is sensed? I typically make PE and BE match at low boost settings, then increase the BE EQ target at higher boost levels.
