Results 1 to 8 of 8
Thread: Camaro SS 2010 LS3 stroker with Comp cams Missfire
    Hi guys, I have a Camaro SS 2010 with those parts inside
    Comp camps camshaft 146-458-11
    Summit Crank 4.00 58x 180LS400058x
    JE Pistons 360772
    ACB Lifter E52 J2079
    Comp cams valve retainers 177916
    Comp Cams valves locator 469516
    Comp Cams valves lock 62316
    Comp cams valve Springs 2626916
    Trickflow VVT delete 30678504 ( I don't understand why, but the read file from the car was already with VVT disabled, but the car had VVT parts on before the engine build)
    Manley rods 14051R-8
    Sparks are NGK TR7EIX gap 0.34" for begining dyno tuning.
    ISSUE
    I have a lot of multiple missfire on all cylinders, I reduced a lot knock sensivity, otherwise ECU pull timing a lot.
    Missfire CEL came on at really rare time
    no other CEL came ON
    AFR is about 0.84lambda (12.3 WOT)
    fuel is fresh from gaz station.
    I don't have any trace of knock on plugs, and I never heard any pre-ignition
    thanks for help
    run21 missfire new spark cable.hpl
    run21.hpt
    Feb 2020
    Metro Detroit Area
    270
    I would start with a hotter plug. TR7 is likely too cold of a plug for initial tuning. You probably will never need a TR7plug unless your hitting it with nitrous or boosting it. Just my opinion though...
    Jan 2016
    329
    You aren't logging any misfire parameters. Does it set a P0300 or a specific cylinder? If you log all misfires for each cylinder, is it all over the place or is the misfire on a certain cylinder(s)?
    What speed and load are you misfiring at?
    Is the rest of the valve train stock?
    Mar 2011
    Ripley, MS
    1,865
    You'll have to desensitize the misfire detection quite a bit with a cam of that size.
    I noticed that you've increased the target idle speed, but haven't increased the min airflow.
    Here are a few pointers that will help get it going.
    Change the cylinder vol to represent the larger displacement, then follow these steps.
    1. Go to Engine>Airflow>Dynamic tab and lower the High rpm disable/re-enable to 400/300 respectively.
    2. Go to Engine>Idle>Airflow tables and add 5 gms/sec to the Airflow Final Min table
    3. Go to Engine>Idle>Airflow and increase the startup airflow by 25%.
    4. Go to Engine Diag>Airflow tab and change Min ECT for P0101 to 256, and change Airflow Correlation RPM from 800 to 8000.
    5. Go to Engine Diag>Misfire tab and change Min misfire detection enable to 2500 rpm.
    Thanks a lot for advices
    1. 400/300 I have a warning from the software : Your entered value exceeds the min/max limits. A value outside limite can cause unpredictable resultas and may posibly put your module in an unrecoverable stable. IF you believe the minx/max limits are in error, please contact support. Would you like to overide the predefined limits for this parameter? yes/NO
    2,3,4,5 are modify now thanks
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by Garrett View Post
    Make sure that you're changing the correct parameters and that the units are in RPM.
    See the pic below.
    See the pic below.
    you are a good one, units wasn't good
    it's finenow
    I give the engine tech, installer and builder some guidelines
    -Ground
    -power cable
    The ground behing the driver side cylinder head wasn't tight
    I pulled 457whp STD on dynojet
    stock intake manifold
    stock throttle body
    stock exhaust manifold
    stock catback
    thanks a lot everyone
