I installed a continental sensor, the same one vermonttuning uses for my make/model, 2017 Camaro 4l turbo, The pin is definitely far enough in and seated correctly, I've taken it out 4-5 times to check for depth of pin #70, no bent pins, the weird thing is that on my HP Scanner it says no Ethanol 0%, But it says 40% Alcohol, I have about 1/4 of 93 & 1/4 E85,When I took out the Plug to double check fitment, I cleared the battery, and the HP Scanner is saying 50.20% Alcohol, but still no Ethanol??? I've read that a 40% reading on the Alcohol could be a defective sensor, Flex Fuel is active, and sensor are both active in Program...Yeah I'm a NOOB.
