Hi guys, I have a Camaro SS 2010 with those parts inside
Comp camps camshaft 146-458-11
Summit Crank 4.00 58x 180LS400058x
JE Pistons 360772
ACB Lifter E52 J2079
Comp cams valve retainers 177916
Comp Cams valves locator 469516
Comp Cams valves lock 62316
Comp cams valve Springs 2626916
Trickflow VVT delete 30678504 ( I don't understand why, but the read file from the car was already with VVT disabled, but the car had VVT parts on before the engine build)
Manley rods 14051R-8
Sparks are NGK TR7EIX gap 0.34" for begining dyno tuning.
ISSUE
I have a lot of multiple missfire on all cylinders, I reduced a lot knock sensivity, otherwise ECU pull timing a lot.
Missfire CEL came on at really rare time
no other CEL came ON
AFR is about 0.84lambda (12.3 WOT)
fuel is fresh from gaz station.
I don't have any trace of knock on plugs, and I never heard any pre-ignition
thanks for help
run21 missfire new spark cable.hpl
run21.hpt
