Originally Posted by
Stock
Ok so if I use the stock pcm I don?t need to adjust anything in the car which isn?t a bad route but can that pcm be tuned for flex fuel? The car is set up for dbc, am I stuck with that? The motor is a gen 4 6.0 with front mount cam sensor and 58x reluctor. Knock sensors on the sides. Right now my intake has a dbw throttle body on it now. I could get another one that?s dbc. Is there any reason I wouldn?t want dbc? Everything I?ve had up to this point has been dbw. Is it harder or easier to tune than the e38?
