Results 1 to 9 of 9
Thread: LS3 Swap from Salvage 2011 Camaro SS - Starts and Dies in seconds
    Potential Tuner 74Bird's Avatar
    Jul 2021
    4
    I am doing an LS3 swap from a salvaged 2011 Camaro SS. I have the engine, trans, ECM and BCM installed. I am using a new Holley fuel tank with pump and an external filter/regulator return. The engine starts and dies in seconds. If I leave the key in the ignition position for some time, it does not start. After it starts and dies, I need to wait to start again. Attached are the DTCs. Any help would be greatly appreciated.
    13,557
    Did you disabled the VATS in the OS tab, then do a write entire to remove it??
    Jul 2021
    4
    Yes. VATs is disabled. But it will only start if I have the original key in the cylinder with the sensor hooked up. Not sure why. Attached is the file.
    13,557
    Disable the starter fault check and code P1631 as well.
    Jul 2021
    4
    Sorry, I am new so to verify, the starter fault check is on the OS section and the P1631 is on the Engine Diagnostics section, DTC's tab, correct? Thanks
    Jul 2021
    4
    Thank you very much for your help! I just figured out that I wasn't writing the whole file. It now runs with VATS disabled.
    13,557
    Yup, a write calibration only is not enough for a VATS removal. Needs a full write entire.
    Nov 2014
    Utah
    60
    5FDP, Is that just on the gen IV engines? I have a 2001 gen III that I did a calibration write only (vats disable) and it runs.
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by SteelGreenStallion View Post
    GEN 3 computers don't require the Write Entire procedure.
