Results 1 to 7 of 7
Thread: OIl and trans temp
    Tuner in Training Burnit53's Avatar
    May 2019
    20
    OIl and trans temp
    Are these values able to be logged on Gen 4? The channels are available in Scanner, but the values are bogus.
    I'm I missing something?
    '07 TBSS. 3SS, 2wd, 402ci, BTR STG 3 cam, Speed LTs w/ catless Y-pipe, HD Spal fans
    '04 DMAX,NOT STOCK!
    13,565
    I think it depends on the vehicle and computer.
    Some vehicles do not have a oil temp sensor. Most trucks have a transmission temp sensor in the valve body so that one should read I believe.
    May 2019
    20
    I got the EOT to work with the "calc" channel, but I can't find a similar one for the Trans if it exists.
    '04 DMAX,NOT STOCK!
    7,635
    Calculated/estimated values will not help you since nobody knows what actual values the ECM is using to do the estimatin'. I think you're better off not even looking at channels like that.
    There is a real physical sensor in the transmission that reports real data. Name is 'Trans Fluid Temp'.
    May 2019
    20
    I'm more concerned with temp drop after heat exchanger install that actual temp. If it's calculating per some formula, it will show a drop of some sort.
    Trans fluid temp registers something like -32*. Not a chance this time of year in Phoenix..
    '04 DMAX,NOT STOCK!
    7,635
    If the TFT is reporting -32 then it's broken. You should probably fix it, or verify with a real scan tool and not something intended as a tuning aid that the sensor is working and reporting correct data to the ECM. HP Tuners is not a replacement for multi-thousand dollar diagnostic tools. Why do so many people think it should work that way?
    Service info says there is a scan tool parameter called 'Engine Oil Temperature Calculated' but gives the description as: "This parameter displays the temperature of the engine oil." IT DOES NOT, as there is no discrete physical sensor, it's just guessing based on... who knows.
    7,635
    IT DOES NOT
    Just to be clear, I'm yelling at the eSI authors and not at you. The correct description for that PID would be something like: "Engine Oil Temp is calculated based on a weighted average blah blah blah using the formula [pointless dumb formula here]..."
