Thread: 0411 LS1 VE Tuning: Why are primary VE table values limited to whole numbers 0-5 only
    Oct 2007
    Waterloo, IN
    26
    See attached screen shot and copy of the stock tune file I'm working with.
    I've never speed density tuned an 0411 PCM before (always do MAF tunes); but a friend needs help running MAFless. This particular OS does not have a secondary VE table so all I have is the primary.
    HP Tuners only allows a 0 - 5.19% value in the Primary VE table according to the legend, but the actual table will only accept "whole numbers" from 0 to 5.
    How are you supposed to VE tune one of these PCMs with this restriction?
    7,757
    Click the 'Add Decimal Place' button a few times.
    How precise do you want it to be? Keep clicking...
    7,757
    You can also change the Units from 'Number ()' to 'Percent (%)' to get numbers that might make more sense. Makes no real difference as you're pasting collected error data which will apply the same either way.
    Oct 2007
    Waterloo, IN
    26
    Thanks! I knew it would be something simple...
