Hello everyone,
2007 GMC Yukon XL SLT with a 5.3 (VIN 3) Engine (NO VSS)
Parts Installed:
Cam: Stage 2 LS Truck Swap Cam, 218/227 112+2, .522/.524 Lift
Lifters: LS7 and guides
AFM OIL DEFLECTOR SHIELD
LS-2 VALLEY COVER
OIL PUMP AND PICKUP
THERMOSTAT 160 DEG
Brian Tooley One-Piece Pushrods
CAM GEAR CHANGE KIT
ACDelco Iridium Spark Plugs
The vehicle runs but not a good throttle response like before, almost feels like it has to catch up to itself. Idle has a slight lope to it.
I know I will need to get disable DOD and get rid of the DOD codes all of which I am not sure how to do yet as I just ordered my device. and not sure if the computer is in some sort of fail mode because of the DOD codes, but if anyone could help with the following it would be much appreciated.
Does anyone know What is the recommended settings for this camshaft? or where I should start.
I would like to remove the speed limitation.
I would like to bring the shifts in slightly harder.
I would like to bring the cooling fans on at 165, 170
Thanks in advance
PoolPro
