Jet boat is back again, new engine, new turbos (twin 63/68 borg warners @ 18psi), new fuel system (Aeromotive Eliminator), pressure set at 60psi which is the same as before with no boost compensation. 80lb DEKA injetors, 5.3L with 853 heads.
My AFR on the wideband is a consistent 7.5 @ WOT. Black smoke like a diesel!
I'm new to HPTuners, I have read the tuning how-to's, but unsure of where to really start in the to get this SD tuned P01 ECM to lean out without doing major damage. Wideband only, no other O2 sensors as this is a BOAT with a jet drive. NO MAF, Basically tuning for WOT @ 6500rpm or cruising @ 3500-4000 rpm, no where in between. Cruising AFR is in the 14-15:1 range and currently ok with that. The major issue is the WOT AFR of 7.5:1 which as low as the wideband reads and there is a A LOT of power left on the table here. Tune file attached. No log file yet. Is there anything that really sticks out to you guys that I should adjust initially?
Jet boat tune download for HPT forum..hpt
