Hello, I'm curious as to what is too lean on decel. I have a 73 c20 with a 4.8 in it with a sloppy stage 2 cam, tbss intake, 3 bolt throttle body, throttle blade drilled out to a 5/32 bypass hole, stock exhaust manifolds to 2.5in dual exhaust no x/h pipe, 50lb Delphi 12613412 injectors, walbro 255 inline pump. As soon as I let off the gas and close the throttle plate it goes super lean and stays lean until I get back into it. I assume this is normal, but how lean that normal is is what I'm not sure of. Currently I'm still just trying to dial in the VE table. Any tips or pointers would be awesome, thank you in advance.
73swap after first drive.hpt
first long drive.hpl
73swap after first drive back.hpt
drive back.hpl
