Results 1 to 4 of 4
Thread: Map points not where distance table is pointing
    Oct 2020
    Florida
    20
    My tune doesnt follow the distance tables at all. As I drive, it stays in MP 14 until I give it enough throttle to go into OP. It has a Paxton SC and its a 6R80. Doesnt make sense to me. Ill share a datalog and the tune. Thanks in advance.
    *Update Im using MPs 14-22 only.
    Mar 2018
    7
    You will need to enable whatever map points you want first
    check your mapped point configuration and snap to point and work it from there
    Oct 2020
    Florida
    20
    Quote Originally Posted by GT stang View Post
    MPs 14-25 are on Snap to are on 14-22
    Oct 2020
    Florida
    20
    Well I figured out the MP problem only to have a new problem come up. For whatever reason the operating system in the pcm was not allowing the distance tables to work. The operating system was VCXQPBD. I replaced it with the roush FSGP1A2. But now everything works except the LTFTs. Datalog shows STFTs but the LTFT always reads 0. Anyone have a problem like this before?
