Results 21 to 40 of 46
Thread: MPVI2+ "No driver found" on new installation
    28,272
    Quote Originally Posted by CBass9104 View Post
    I did a couple weeks ago. Ticket number 19655.
    Or do I need to send another request?
    No, I've sent you an email with the files/instructions.
    Jul 2021
    San Antonio, TX
    13
    I received the email. I use Outlook and it blocked the driver file because of the file type. I did a work around with the registry and got it unblock. The driver is installed and I resynced the MVPI2+. Now on to the next step for me.
    Y'all lived up to your quote "It doesn't have to be perfect, it just needs to be done in two weeks..."
    Thanks for the support!!!!
    Aug 2021
    I?m having the identical issue as the OP. Are the latest drivers on the site yet or will they be sent to my email in response to my support ticket? Ticket number is 21710. Thanks.
    Jul 2021
    San Antonio, TX
    13
    Quote Originally Posted by Josh94Z View Post
    They will email you the drivers through your support ticket.
    FYI- The drivers worked for me and I have been tuning succesfully!
    MPVI2 + windows 7 driver not found
  6. #26
    28,272
    Quote Originally Posted by Haider Alshaban View Post
    I'm sorry you're having troubles and we'd love to help you. Have you already opened up a support ticket? If so, do you have your ticket number so that we can review the status? If not, please open a support ticket here: https://support.hptuners.com
  7. #27
    Could someone send me these drivers to try I’m having the same issue right now. Plz help. [email protected] is my email
  8. #28
    Oct 2021
    Any fix?
    Delivered today.
    Opened today.
    Plug in.
    POS. I have a $500 paperweight.
    Why are the drivers not publically posted?
  9. #29
    Dec 2011
    I have the same problem.
    Weird thing is that I used a buddies MPVI2+ on this computer while I was waiting for mine(MPVI1 upgraded) and it registered without a hitch. I get mine in the mail and won't recognize after upgrading, uninstall re-install.
    Filed a support ticket. Waiting..
  10. #30
    Oct 2021
    46
    People have to realize it is impossible to test the device and software on every possible OS and hardware combination out there.
    Development is a process.
    Microsoft itself dropped support for Windows 7 February of 2020.
  11. #31
    Potential Tuner snead317's Avatar
    Nov 2021
    Tulsa
    I’m having the same issues with the drivers not installing correctly using windows 8.1. When I connect MPVI2+ to laptop it says unknown device drivers not installed. I’ve downloaded the driver setup file from website and followed the instructions in the box and purchased my MPVI2+ with 2 credits directly from hptuners.com I’m in need of support
  12. #32
    Unhappy MPVI2+ "No driver found" on new installation I received my new MVPI2+
    1. I?m using running Windows 7 Professional. The system processor, RAM, and HHD specs are greater than the minimum requirements for the VCM Suite.
    2. I downloaded the VCM Suite, version 4.10.7 and installed.
    3. I plugged in the MPVI2+ using the supplied USB (A to C) cable.
    4. The system searched for the drivers for the MPVI2+ and I receive a Windows systems message stating ?Device driver software was not successfully installed? and stated the specific reason ?No driver found?
    5. I went to the HPTuners website and downloaded the MPVI2+ driver from the link on their webpage. I received the .zip file labeled CDM21228_Setup.
    6. I unzipped the file and ran the executable file CDM21228_Setup. I received no errors and it appears the file ran correctly.
    7. I plugged in the MPVI2+ device, again, and received the same Windows system message ?No driver found?
    I have removed the device and the VCM Suite software and reinstalled multiple times, to include installing ?
    Any suggestions for installing the MVPI2+?
  13. #33
    Feb 2020
    Metro Detroit Area
    263
    Upgrade to Windows 10, its free and not that hard to do
  14. #34
    Mar 2009
    S. Florida
    582
    New computer will not recognize MPVI2+ Drivers are there, USB acknowledges it. Will not sync. Using windows 10. Acknowledges my old MPVI1 PRO.
  15. #35
    Mar 2009
    S. Florida
    582
    My old computer acknowledges it.
    Will not sync.
    Using windows 10.
  16. #36
    I'm having the problem too.
    Hi Bill, I submitted ticket 33118 and I'm having the exact same issue as all the others in this thread. Windows 7 laptop will not recognize my MPVI2/RTD+ tuner. Installing and reinstalling the newest downloaded drivers does not work. Any help is truly appreciated!
    Thank you kindly!!
  17. #37
    Can anyone email me the drivers please as mine arrived today and I'm having this same issue.
    [email protected]
  18. #38
    Jan 2022
  19. #39
    Feb 2022
    11
    Hi HP Tuners.
    I'm having this same issue, when using the drivers posted on the website..I've opened a support ticket.
    I see that when you reached out and shared some files, others were able to get their HP tuners working.
    Can you share the alternate files somewhere so that everyone who comes across this can have access and resolve their issues?
    Thanks!
  20. #40
    Feb 2022
    11
    Quote Originally Posted by tkwyo12 View Post
    Hi HP Tuners.
    Thanks!
    So I ended up updating to windows 10 64bit pro. (since I"m running this on a virtual machine). Can get to the point of reading interface while performing a resync, however it doesn't complete. I've revised my support ticket. Hope to get this thing up and running soon.
