My truck is 76 C10 with a 2004 LQ4 w/799 heads, BTR Truck stage 3, 2010 flex fuel injectors & 4L80e w/3000 stall. Been through VE and MAF tuning a couple of different times to check things and to tweak after some of the changes that were done in stages(Injectors, X-pipe exhaust, H-pipe exhaust). Also done braf config a couple of times. If some one wants to take a look and tell me if I've gotten something way wrong I'd appreciate it. If not, no biggie, I've been lurking for awhile and a couple of you guys are very knowledgeable and I'll keep reading your posts. I do struggle with stalling coming to a stop occasionally that I can't get 100% licked though I have gotten it better, the Aug9PM log file shows it dipping low.
For the timing when knock is seen, I struggle with how much to pay attention to logged knock. For example we look at 15-50 hits for VE cells and ignore cells without enough hits so it doesn't skew all over the place. With Knock retard should I do the same? Do I ignore less than say 5 hits in a cell or do I make a change after 1 hit of knock in a cell? The tune attached I went back to having the High and low matching specifically to check and adjust for knock. Prior to this I had the whole low table 4 degrees less than the high table.
Logs are from the the other day no changes made in between other than it was hot and humid in the PM. The logs are mostly cruise, not the greatest representation i know.
Even if no one takes a look, thanks for helping everyone else on here I've learned a lot an could not have done the swap without all the info found here.
