Results 1 to 7 of 7
Thread: fuel sender
    May 2006
    3
    fuel sender
    I have a 02 Silverado and just recently installed a 20 gallon fuel cell in it with a 90ohm sender unit. From what I read, the factory sender unit is a 250ohm setup.
    Is it possible to change the settings with HPtuners so that my fuel gauge will register properly? If so, how would I go about doing that?
    Any suggestions are greatly appreciated!
    May 2006
    3
    t t t
    Apr 2003
    Almost 2000 feet.
    7,876
    Most likely you will need the correct ohms. Not absolutely sure though.
    However, you can log the fuel gauge stuff while you add a gallon at a time (or whatever) to fit a corrected curve.
    Always Support Our Troops!
    Oct 2008
    24
    Did you ever figure it out? Im using a 15 gallon tank with the 90ohm sender. Any help is appreciated.
    Advanced Tuner sarg's Avatar
    Aug 2011
    Atlanta, GA
    305
    Have not been able to find anything on this either. 2000 fbody gauge with a 0-50 ohm sending unit in the fuel cell. Anyone have suggestions or know anything about this?
    May 2013
    4
    Anyone? If not then I will attempt. I just didnt wanna F*&^ anything up.
    Mar 2009
    Andover, MN
    458
    Anyone have any results?
    I am debating on a fuel cell right now from aeromotive, which has a 0-90 ohm sender.
