Results 1 to 5 of 5
Thread: 2013 ZL1 won?t start unless spraying meth to start
    Hi Guys,
    Buddy of mine has a 2013 ZL1 with LSX B15 block, cam, etc. Installed some FIC injectors and injector data. Car started fine and he did a couple logs and drives.
    Parked car overnight and now it won?t start. Got fuel pressure and spark. It just cranks, but doesn?t fire. It does start and stay idling if you run some meth through it while cranking. Any ideas what it could be? Also installed new battery today and it?s the same.
    13,565
    I would be double checking all the injector data.
    Aug 2008
    Chicago
    98
    Check your injector data like mentioned and post a File and data log.
    2000 WS6 Trans Am LS3, Tick Performance Stage 2 cam, ARH 1 7/8" Headers, FLT Level 6 4L60e, Circle D 5c Launching on a 200K 10 Bolt
    2001 Camaro SS M6 Black on Black
    Aug 2014
    Central, LA
    737
    Which FIC?
    Sep 2012
    CA
    45
    Listen to see if the fuel pump re-primes itself when it fails to start. Could be your pump is not on during eng. cranking
