Results 1 to 10 of 10
Thread: Gen 5 2015 denali 6.2 afm delete , rough idle / code question.
    Apr 2011
    10
    Friend of mine has a 2015 denali 6.2 had a lifter/camshaft fail. Pulled motor did a BTR stock replacement camshaft kit (lifters , cam, plugs, ect) , truck is back together and running good but has a rough idle and will throw a P219B for a "generic" code. My question is all I did was go in and click "afm disable" and wrote the changes. Do you think this could be something to do with all the other box options that can be clicked? And if so what ones ? Thank you ahead of time.
    Mar 2020
    380
    Post your tune file for help. Also, do you have a datalog you can post?
    Apr 2011
    10
    File is on my laptop at home... Truck and tune is bone stock... I clicked one box "DOD DISABLE" thats all..
    Mar 2020
    380
    DTC P219B - Fuel Trim Cylinder Balance Bank 2
    This code indicates the fuel trims between cylinders on bank 2 (passenger side) is beyond the allowed % of error. Lots of suspect reasons to cause this, but the best way to help will be posting a data log so we can see what is going on.
    The master enable/disable button on the delete SHOULD be good, but I always double down on it with a choice in the menu below it also. My go to, is to raise the "Enable ECT" to 400 degrees.
    What is the status of this DTC? Pending/Current/Permanent
    13,565
    Is it a VVT delete camshaft as well?
    Apr 2011
    10
    ITs a BTR AFM delete camshaft.
    Apr 2011
    10
    CAMSHAFT
    1 x BTR CAMSHAFT - 6.2L L86/LT1 DOD DELETE CAM - 2240006175
    Apr 2011
    10
    Quote Originally Posted by fatblockvelle View Post
    CAMSHAFT
    I will try and get a log. ty
    311
    There asking if you installed a lock out for the VVT
    Apr 2011
    10
    Quote Originally Posted by Jonblarc7 View Post
    We did not install a VVT lock out.
