Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Thread: 6.4 help with mods unknown tune attached
    Jun 2018
    Albuquerque New Mexico
    467
    Quote Originally Posted by Srpracing View Post
    Does any know why some tunes zero out the MAF Airflow Diagnostics Enable table? Stock has values but SCT and H&S zero it out.
    Attachment 113515Attachment 113516
    This means the MAF won't toss codes, 1 means enabled at those rows and columns 0 means disabled. They are avoiding having airflow codes pop up later if the MAF isn't seeing enough or too much airflow. They should be left on and scaled appropriately for the new tune but setting them all to 0 is the easy button.
    Feb 2016
    USA , I travel and build race trucks
    28
    hs turned off air flow meter diagnostics just to cover more vehicles simple as that those tunes went in 10s of thousands of trucks so they simplified the tuning so it was not a diagnostic nightmare on there end. i also turn this off as when it is on and some thing is exsactly right it defuels when it shouldnt.
    Jun 2020
    San Diego, CA
    20
    Say if I were keeping stock timing/fueling, should I leave the MAF diagnostic on?
    Jun 2018
    467
    That code was designed for finding boost leaks or broken turbos by setting a low flow code and where stuck vane control can make its overboost easily apparent in low rpm/torque areas. The high flow code is actually hard to hit. It's really only achievable if the vanes are stuck basically 100% closed on a stock compound setup. I highly doubt you'll hit it on either end, especially if your maf is scaled properly and you're on a stock compound setup. The stock limits are well set for stock turbos, big single turbo guys will hit the low flow code as most single turbos spool later thus not flowing as much relative to the compounds in the lower rpm/torque areas where this table is set to be on.
    Jun 2020
    San Diego, CA
    20
    Quote Originally Posted by JaegerWrenching View Post
    Thanks, that makes a lot of sense.
  6. #26
    Jun 2020
    San Diego, CA
    20
    After spending a lot of time dialing in my tune, ive noticed SCT and H&S really didnt know what they were doing. As in a lot of their adjustments caused more harm to the engine than good.
  7. #27
    Banned
    Jan 2020
    Arlington WA
    250
    What was your first clue
  8. #28
    Jun 2020
    San Diego, CA
    20
    Is there possibility anyone has the table identifiers for the PW tables, so that HPT can add them? Based on my tunes, PW1 and PW2 are quite different compared to how HPT shows.
  9. #29
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    474
    You talking about the actual parameters or the Axis numbers?
  10. #30
    Jun 2020
    San Diego, CA
    20
    Sorry, I meant the actual location of the tables in the calibration. HPT needs the actual location in the .phf file in order to add the correct tables. I could be wrong, but I believe PSM 6.4 found them. 5 of the tables.
  11. #31
    Jun 2012
    warrenton va
    474
    From what I have learned. SCT does is the one that?s wrong.
    There is padding and or a bootloader that SCt does not define.
    Like in the 6.7 stuff it?s 80000000 that needs to be added to the sct address to get it in range.
    Then there are offsets that have to be found.
    Email me what you?re looking for and the Strat code and I?ll see if I can dig them up. PM me for my email.
  12. #32
    Jun 2020
    San Diego, CA
    20
    Quote Originally Posted by PSM 6.4 View Post
    Side note the 5 different PW tables do exist in the stock strategies.
    1 and 2 are used, 3-4-5 isn?t utilized. So they don?t show it in HPT.
    I just realized this is correct. The 6.4 utilizes Config 0 and 1. It does not touch Configs 2,3, and 4. That being the case, it could mean - PW #1 = Config 0. PW#2 = Config 1.
    OR
    PW#1 could be when the truck is normal state and PW#2 being when the truck is in Regen.
    MCC shows 4 PW tables and utilizes them all for SOTF. I dont think VCM suite displays the tables correctly as theyre not used to all PWs being used. Hence why it looks like PW1/2 are mismatched.
