Results 1 to 5 of 5
Thread: HELLCAT engine swap low boost
    Oct 2017
    MEXICO
    44
    hi im working in a grand cherokee with a hellcat engine swap, but my main issue i cant handle to build more boost than 3-4 psi so im asking for a help to raise the boost atleast to 7-8 psi via bypass valve or more if possible, any idea is welcome
    here is the tune file
    Tuner fumanchu182's Avatar
    Oct 2019
    Maryland
    78
    What year did the swap come from, when I did a comparison from a 2016 Challenger Hellcat Stock it matched 1:1? Do you have a log with data of a pull at wot?
    Hellcat PB > ET: 10.092, MPH: 135.650, 60': 1.492, R/T: .000
    Bone Stock Scat Pack PB > ET: 11.612, MPH: 119.52, 60': 1.634, R/T: .000 (gone but not forgotten).
    https://youtube.com/user/fumanchu182
    Oct 2017
    MEXICO
    44
    its a 2016 hellcat engine with 2016 hellcat ecm, dont have any datalog but i just seen just making low boost, thats the actual issue, i mannaged to change the afr via VE with wideband cause dont even enter into power enrichment
    Oct 2019
    Maryland
    78
    If its 100 percent stock the ANN setup should have seen full boost without issue.
    Oct 2021
    10
    check bybass via hoses map
