Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 75
Thread: Scanner Configuration & Histogram Repository
  1. #21
    Advanced Tuner 405HP_Z06's Avatar
    Feb 2004
    Arlington, Texas
    270
    2008
    Chevy
    HHR SS Auto
    PCM 12625310
    TCM 24243902
    3GNCA63X88Sxxxxxx
    General Tuning
    Misfire and knock tuning config file.
    NOTE: Do not open the .cfg or .hst files with anything but the scanner.
    For version 2.22 and later, file locations are as follows:
    The .cfg (configuration files) are located:
    C:\Documents and Settings\<USER NAME>\My Documents\HP Tuners\VCM Scanner\Configs
    The .hst (histogram files) are located:
    C:\Documents and Settings\<USER NAME>\My Documents\HP Tuners\VCM Scanner\Histograms
    Aaron
    '03 Z06 Corvette - The Normal Stuff.....
    EFI-101, EFI Advanced, EFILive-101, Variable Camshaft Tuning
    EFI University Evangelist
  2. #22
    Jul 2008
    TN
    14
    Anyone have anything for the L61 eco for the cavalier?
    '92 Typhoon (GM crate engine, TD06H, diacom, 19 psi) needs tune
    '98 corvette. 6speed (12.79@110)
    '04 Cavalier. ecotec 5speed dailydriver. body kit. 35mpg. (10.15@69 1/8th) slow
  3. #23
    Jun 2007
    19
    I cant seem to load the attached files. Specifically the 2.0t tune. It sais "unable to parse log" Any ideas?
  4. #24
    Feb 2004
    Arlington, Texas
    270
    Quote Originally Posted by MaxiM_X View Post
    Which attached files, specifically and what are you referring to as '2.0t tune'?
    Aaron
  5. #25
    Jun 2007
    19
    The solstice, sky, cobalt 2.0t tune available in this thread.
  6. #26
    Feb 2004
    Arlington, Texas
    270
    There are not any .hpt file's in this thread. These are all configuration (.cfg) and histogram (.hst) files.
    If your looking for tune files (.hpt), the tune repository is the place to look.
    Aaron
  7. #27
    Apr 2006
    No where in particular
    65
    Here's what I'm using now
    2004 Saturn Ion Red Line
    SD / Misfire Tuning
    Wideband: Innovate Motorsports LM-2
    Only thing I can't figure out is the boost parameter - I used to have a custom (user defined) PID which took the MAP and current Baro readings, and converted it to the REAL boost...for whatever reason (perhaps software updates?) it doesn't seem to work anymore, and I can't remember how to set it up.
    04 Ion Red Line - Black "Stealth Beauty"
  8. #28
    Advanced Tuner GeoffH's Avatar
    Jul 2009
    Panama City, Florida
    344
    I'm posting this one with baldturbofreaks permission, some of it may be over the head of the avg user but is a very good config IMHO.
    I'm also working on a few varients of it but it may take a while.
    This should work on all the 2.0t pcm's ie solstice gxp, sky redline, cobalt ss/tc, & hhr ss/tc
    I can't open log, it says: Unable to parse log
  9. #29
    Jul 2009
    344
    I was able to find it, but it is so big on my lap top, i can't see everything
  10. #30
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    If you get an error opening the cfg, download it into the config folder under the scanner and then open it with the scanner software. The one I just posted above wouldn't open correctly until I saved it locally. I have the latest beta here.
  11. #31
    Thanks man
  12. #32
    Advanced Tuner HawkZ28's Avatar
    Feb 2009
    Waverly, NE
    475
    Here's the 2 that I've been using on our 02 TB and our 05 Colorado......I have to give credit to Trailblazin and Doug- I've built on plagarization! I used theirs as a base, and built on it to filter out more conditions that we generally turn off in the tune.
    With these 2, you don't have to worry about PE, and DFCO depending on your DFCO map settings. You can always adjust it in the histo filter to your settings to weed out DFCO.
    I'll apologize in advance for the lack of order in the TB config.
    Hawk
  13. #33
    Sep 2006
    Arizona
    600
    Still nothing for L61's?
  14. #34
    I have tried severeal times to create these and EPIC FAIL!
    06 Cobalt LT pacesetter cat back, eibach lowering, AEM CAI, Zex 75 shot. 190whp
    09 CObalt SS, Dejon spring mod, Hahn catted Down pipe, 3" cat back with a borla muffler. Still slow...
  15. #35
    Feb 2010
    Indiana, Pa
    2
    Unhappy
    Quote Originally Posted by Iam Broke View Post
    Hey i tried everything and i'm still getting that unable to parse crap. I have a 06 m6 GTO and ever since i've had it, the first histogram (Main spark timing advance, engine speed vs g/cyl) Only plots at the last row. Every other log i pull up, for other peoples cars, it shows the the same thing. I know its probably a problem with the configuration of it but i can't figure it out.
    Please help!!!
  16. #36
    Feb 2010
    Indiana, Pa
    2
    ???? Anyone......
  17. #37
    Jun 2008
    21
    Quote Originally Posted by 1107359429 View Post
    ???? Anyone......
    You need the beta version it seems
    02 GP GT top swaped...some other mods, headers waiting to go in
  18. #38
    Aug 2007
    503
    Here's another lnf config, its about as sorted/grouped as it can get. You'll need to add these 2 custom pids.
    Boost: Sensor - Manifold Absolute Pressure
    Function: [PID.11.PSI]-14.5
    LTFT+STFT: Sensor - none
    Function: [PID.6]+[PID.7]
    Fixed o2 b1s2 pid.
  19. #39
    Jul 2009
    344
    Thanks Shabby, I will try this out in the morning
    2008 HHR SS 5-speed
    HP-Tuned
  20. #40
    Nov 2009
    21
    where can i get the latest beta version i think im not able to open any of these due to that. get the same error as maxim_x
