To start with I am running a speed density only tune using the factory map sensor. I did not change the OS. Engine has a mild cam, intake and exhaust. When ambient temps are 80?F and above I have no issues at that point. Temps recently dropped in to the 50's and 60's at night. My problem is... I go out to the truck in the morning and start it up and pull it out of the garage and everything is fine. I put it back in drive and it is fine, as soon as I start pulling out of the driveway, it stalls. I drove all of the way to work (17 miles city and highway), after 10ish miles on the interstate I turn off and it stalls at every light unless I hold the throttle open some. I pulled over this morning and it tried to stall so I let the intake air temp warm up to above 80?F and I had no more stalling during the rest of my trip (of which which was short and IAT did not have a chance to cool off. Looking at my logs, I see no excessive rich or lean condition causing the stall. The only thing that I am seeing that makes a difference is IAT. What info do you want to see to get a better idea? Or do you have an idea already?racing timing 28 6500rpm-2 cold idle correction att.hptmorning stalling.hplevening no stall.hpl
