I noticed you can?t log aircharge anymore. I was logging it and had a chart like the spark table. What is everyone logging now?
Common. What version of VCM are you on?
If in doubt, multiply everything by 1.1.
4.9.873 beta. Is there a fix?
Install a different version and re-poll for supported parameters. Then delete your old aircharge channel and go select it again.
Check your PMs. Using older versions is against the HP Tuners user agreement.
I'm having the same issue on 4.10 and I've tried for different cars from 2012 to 2021 aircharge wont show
For anyone having this issue, create a support ticket with HP Tuners. This seems to be an ongoing problem with scanner.
In this post some had the same issue and it seem like it was removed on purpose.
https://forum.hptuners.com/showthrea...-Now-Available!
