Ever since the goat was procharged, traction control will sometimes turn itself off. I have tried to figure out when it was happening and thought it may be an effect of burst knock, but I have since tuned the delta air and it is still happening.
It will happen right at startup usually (although sometimes it happens after it's driven 1/2 mile or so).
It's running a 2bar SD OS. Has anyone seen this before and how did you fix it. If it turns itself off, you can't turn it back on.
