i have a 2010 F150 with a 5.4 flex fuel non ecoboost is there any way to delete the PATS system using HP Tuners or is there any other system/program that will do this
Working on a 2010 F150 as well and I don't see the PATS switch in the system section. I also did a search in the navigator and nothing came up. Do we not have access to this in newer F150s? Getting a code P1639 vehicle ID block error and crank but no spark situation.
Paul
Modern Muscle Motorsports
www.modernmusclemotorsports.com
Custom tuning using Diablosport, SCT, HP Tuners, Tuner Cat, FAST & Holley
Dynojet 224x mobile dyno
Any more insight into these? I have a 2010 F550 that did had a cluster take a puke. Put a used one in it. It had pats, truck didn't. Now I can't get it to start. It had a pats switch, but still getting pats codes and no crank. Factory cluster is on eternal back order. Looking for a solution. Thanks!
