Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: 2013 Ecoboost F-150 keeps dropping boost
    Advanced Tuner Japeatr's Avatar
    May 2010
    Dallas Texas
    321
    I am trying to hunt down an issue with my truck dropping boost. it will spike to about 20psi then pull boost back to ~10 no matter the settings.
    i have checked the BOV and IC clamps. but wondering if we are missing something in the tune that keeps pulling it back.
    any help would be appreciated!
    384whp/303wtq
    Built 2.0LSJ: TVS w/2.6, 1000cc, Stage 2 cams, custom fuel system, E85, Dual Pass, 3"intake, 3" Catless exhaust, CIA midlength Header
    May 2010
    Dallas Texas
    321
    logs attached - log 2 you can see if at 3:59-4
    384whp/303wtq
    Sep 2019
    22
    and you need to log limits
    May 2010
    Dallas Texas
    321
    Thanks ill try! Do you have some histograms or configs that would help?
    May 2010
    Dallas Texas
    321
    thanks let me give it a shot!
    384whp/303wtq
    May 2010
    Dallas Texas
    321
    Much better, I didn?t get a chance yet to grab a log or a full WOT pull but can already feel less hesitation than before
    Ill grab a log later today
    May 2010
    Dallas Texas
    321
    Didn?t get a chance to log it but it is so much better. Truck pulls super hard, just need to verify the computer is reading 20psi and fix the 1-2 and 3-4 shift under wot and im set!
    Big thanks kel83 for the assistance!!
    Also got my forscan cable today, any recommendations for niftyness would be cool too
    May 2010
    Dallas Texas
    321
    ok still appears to have an issue, any thoughts?
    log attached
    384whp/303wtq
    Jul 2016
    Fort Worth/Dallas Texas
    29
    Quote Originally Posted by Japeatr View Post
    log attached
    The thing that stands out to me, is your Wastegate Canister Spring Preload. It is set at 1.47 psi and most of the stock ones I have seen are around 4.75 psi. Have you changed the wastegates on this vehicle (if so, the 1.47 psi may be ok)?
    On a side note, I do not think it's your issue, but your EOI Clip is pretty high at 665 degrees. This allows for injector opening well into the compression stroke which seems off to me.
    May 2010
    Dallas Texas
    321
    I cant seem to find Torque airflow limit and torque max protection source?! What am I missing?
    Sep 2019
    22
    Ok, if you add channel in scanner, use filter limit and source, after add all what you see
    May 2010
    Dallas Texas
    321
    Let me know what you think? Seems like truck isnt pushing more than 12-15psi, but is holding it better!
    384whp/303wtq
    Sep 2019
    22
    your limit
    May 2010
    Dallas Texas
    321
    Ahah! You the man! Is this for cats or manifold protection? I guess what im asking is how high to raise it?
    May 2010
    Dallas Texas
    321
    Disregard last question, I just needed to read and determine rate of change
    May 2010
    Dallas Texas
    321
    Upped the temperature limits in the higher load cells above 4k rpm by ~75F, and the surrounding cells in ~3k by 15-25F. Going to start here and see how it runs.
    Also put in a 160F tstat as my fans were working a$$ off trying to keep desired ECT
    Sep 2019
    22
    Achievements?
