Results 1 to 3 of 3
Thread: Pushbutton high idle?
    Got a bit of an unusual idea, vehicle is 66 ford f500, 2001 5.3l attached to original ford 4spd manual.
    It has a hydraulic pto drive that operates a dump box. On the original engine I had a cable operated high idle that helped give needed rpms for the pto.
    Would it be possible to wire a switch to ac compressor input on ecm, and have a push button high idle?
    Mar 2011
    Ripley, MS
    1,865
    Sure thing. It'll just think the AC is on and increase the idle speed to the commanded "AC on" speed.
    Nice I was thinking that's how it would work.
    Would I apply ground to "a/c compressor cycling switch" pin 55 c2 "red" connector?
