Originally Posted by
Thatwhite5.0
7 is a blending mapped point. I'd say mapped point 7 through 20 are all blending mapped points. Their main purposes are to transition into Optimum Power which would normally weigh in MPs 21 to 25. These are your more aggressive, power producing valve events are.
The mapped points the weight falls in depend 100% on cam angles. Your IVO could retard from 0* to 5* to 10* to 15*. Your IVO alone would cause blend MP 21 (IVO 0*) MP 20 (IVO 10) and MP 22 (IVO 15).
Your EVC is probably some where in between 10 and 20*, which would cause more weight in MP 21 (EVC 20*) and MP 20 (EVC 15). This is why you see more weight in MP 21 and 22 WOT.
MP 21 is IVO 0, EVC 20
MP 22 is IVO 15, EVC 22 which is high RPM OP angles. At low RPM, the weight will be in MP 25, IVO -20, EVC, 20. Then it will blend from MP 25, to 21, to 22.
Your OP Thresholds need to be met to achieve Optimum Power. You can rescale both of the tables from 6000 to the RPM you desire for your load and throttle thresholds.
The "OP" Mapped Point will not be used. "OP" on an S550 are the IMRC open mapped points and like I said normally run between 20 to 25.
The information is scattered all over the forum, you just have to locate it. The answer to your question could be post number 120 on a 30 page thread. When tuning the coyotes first became supported, "backwards" is all we had and some of us did a lot of work, a lot of trial and error to learn this. A lot of us are still learning and discovering the operation and structure of how the engine and transmission works as one.
