Results 1 to 2 of 2
Thread: 09 GM Truck 6L80 torque management
    Mar 2021
    8
    Can anybody help with tuning the torque management on this to help the shift firmness but not get into trouble?
    Jul 2020
    VIC Australia
    1,149
    Lower these to start with. They will globally effect any engine load. Then when you've got the hang of it use the adder modifier to fine tune different load points.
    If you're not pushing to much power or pulling big loads 0.7 will get you close.
    Search for user 5FDP posts. He has spent alot of time on truck trans tunes. They can't be treated the same as sedan tunes due to your extra weight and the your greater capacity to tow large loads. In one of his posts he gives away his tune so if you can find it that would be a good asset to have to help you start modifying your tune.
