I'm helping out a shop that installed a 2005 L59 5.3L into an old Toyota. They swapped over the PCM, Engine, APP, TAC & Harness. I deleted the VATS, and got rid of some other codes. After the install the engine runs well, but will not rev over 2000 rpm. The PCM cuts injector pulse at this point. I verified this with a scope. It is NOT going into reduced power mode based on data PIDs, and no codes relating to whats happening.
The vehicle has a manual transmission, but the PCM came out of a truck that used an auto. I tried segment swapping in the manual transmission segment from an 05 file I found in the tune repository. No change. Anything I'm missing? is it looking for a trans speed signal? Any help is appreciated. I've attached the tune files before and after the segment swap.
Thank youLs tune before seg swap.hptLs tune after seg swap.hpt
