Results 1 to 9 of 9
Thread: 2021 Mach1 with P1X hitting ETC FMEM
    Sep 2018
    US
    101
    Car won't rev above 4900. Stumbles and hits ETC FMEM. Was in process of dialing in MAF when this happened. Air Load showed 2.1 and my Air Mass Max was 1.85 so that may be my issue. Have not started back up today on dyno but wanted to post the last tune and log to get some feedback on possible issue/clip I'm hitting.
    Feb 2016
    482
    tune is way off
    Sep 2018
    US
    101
    I haven?t done much supercharger tuning and I?m open to any help or suggestions. ?Way off? in what regard?
    Nov 2009
    All Around
    3,149
    list your mods
    fuel injectors
    fuel system
    pulley size
    hitting above 2 in load is either your running crazy boost or your injector setup is wrong
    Sep 2018
    US
    101
    P1X large pulley (7-8psi)
    DW 95lb injectors
    DW400 pump
    Long tube headers
    Tuner barkingspud's Avatar
    Mar 2006
    NW Burbs of Chiraq
    119
    Your STFT's are waaayyy off.
    Sep 2018
    US
    101
    Nothing was way off. I did make some minor MAF adjustments but the clip I was hitting was In Eng Diag tab under Airflow, there was a Max Load table I needed to bump up the max load a bit in upper RPM. Car dialed if fine after that and made good numbers. Thanks to all who chimed in! Car runs great now, very pleased with results!
    Oct 2016
    Poland
    1,750
    He's right - your MAF curve is all over the place, this tune is just bad. No your car is not running great with a tune like this...
    Sep 2018
    US
    101
    Completed the MAF tuning, car is running great. Thanks for input
