Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: 2014 l83 6l80 injectors wont fire
  1. #21
    Dec 2020
    46
    the only thing i think is the harness is bad
  2. #22
    Jan 2016
    329
    No, we want the scan from the VCM scanner, check out you tube to find out how to do it.
  3. #23
    Dec 2020
    46
    good night this should work
  4. #24
    13,565
    You got lots of codes on that log and stuff not working.
    There is no MAP sensor, intake air temp sensor working. The throttle reads 100%, so I would assume if that is true it would maybe be in a flood clear mode.
    I'd want a better data log, something about the stuff going on in this one is just weird.
  5. #25
    Jan 2016
    329
    Looks like there is something going on with the harness or not everything is plugged in or properly grounded.
    Using a noid light on a direct injection injector isn't the best way to diagnose injector circuits as the boost voltage is around 65V and noid lights were never meant to operate much over 12V. You should be using a oscilloscope with an amp clamp of the correct range to get a good signal.
    That being said, we need a log of you actually cranking the engine over.
    I think 5FDP is on to something with the clear flood mode, commanded EQ ratio is .190.
  6. #26
    Dec 2020
    46
    correct the intake is of because im testing the injectors with the Noid light let me put the intake back on and fix all the codes and i will give you a new log
  7. #27
    Dec 2020
    46
    her is the start with everything put back
  8. #28
    Jan 2016
    329
    There is no RPM signal in that log. Is the crank sensor plugged in?
  9. #29
    Dec 2020
    46
    yes
  10. #30
    Dec 2020
    46
    i just don't know next step is new harness i would prefer not to piss away 1000 dollars if mine is working please look threw it and let me know i have changed all the DTS settings to see replaced the high pressure pump fuel rail sensor I'm not seeing oil pressure but I'm getting it oil pressure
