Results 1 to 6 of 6
Thread: Please help
    Sep 2021
    3
    Please help
    01 chevy 1500 5.3 4x4. Vats system is driving me nuts. Changed it to pwm and set related dtcs to no error reported, still will not start....
    13,564
    The VATS needs to be changed to "none" if you want it off.
    Sep 2021
    3
    Thanks, I tried that as well. Still will not crank. Any other ideas?
    405
    2,322
    Cranking is the key lock cylinder and the BCM or starter problem. PCM only controls the fuel side of VATS. Turning VATS off in PCM will not fix no crank issue. Cranks, starts and runs for a few seconds then dies, turning off VATS in PCM fixes that.
    Sep 2021
    3
    Awesome, that's the kind of info I needed! Guess it's time to get out the test light again. Can any BCM programming be done here with hp tuner? Thank you again!!
    405
    2,322
    No BCM programming with HPT.
