I sorted it out but thanks for the reply chadtunes
What was it?
Apparently it was preventing all the torque during shift which was causing the TMA to kick in. Setting these to disable basically turns off (or down) the torque management. Also someone noted that my shift times were way high so I adjusted those as well. Had to play with the Virtual TQ at that range until I finally got the numbers right. Too much and it would pull throttle, too little and TMA would kick in...very finicky!
Once I install my twin turbo kit, I 'll enable these and go from there so I don't destroy my transmission.
This was also discussed over here in more detail...
Ok thanks for the info. I'm working on a stroked 6.2 and will be adding a turbo at some point once it's in the truck..
I did have a ProCharger with 18psi boost but never got that far with it before I removed it. I was able to get the fueling almost perfect so gonna use that as my starting baseline tune so I don't have to manually build the VVE table again. What a pain!
Yea, that's good to hear. I recently got my 07 F350 dialed after 2 years of head scratching. I'm trying to get ahead of it by digging into others logs, building up histograms, graphs looking for trends and getting all information I can get so it's not such an uphill battle.
C
