I am looking to get some help with a tune. This is in a 2005 Envoy that was an original i6, swapped over to a 5.3 with a Blue/Green ecm 5 years ago. Vehicle ran awesome until it recently spun a rod bearing. So swapped to a 6.0.
I recently installed a gen 4 6.0 .030 over. Crank was changed to be a 24x, cam is a 1x with a LS2 timing cover. Ported set of 862 heads. NNBS intake and 87mm throttle body with x-link, gold blade truck throttle body. Using a TAC module and pedal (don't recall what it is out of) Injectors are a 12564512, MAP 213-4760, MAF 19330121 with a 4" intake tube. The CAM is 227/239 adv.290/305 with a 3200-3600 Circle D stall. Has Kooks long tube headers only using front 02 sensors.
Feels like I am not getting full throttle. With the engine off looking at the throttle plate, looks to only open 40%. Started with LQ9 tune from a Silverado. With the pedal to the floor it shift at about 4000rpms.
Completely new to the tuning and have been reading and watching videos.
