Results 1 to 9 of 9
Thread: 5.3L won?t go into closed loop P0134, P0154
    Sep 2021
    8
    89 S15 Jimmy with a 5.3L DBC out of an 02
    Runs good but keeps throwing the two codes. O2s are new. I didn?t do the swap but I?m the one who bought it and is fixing all the mistakes lol. Any ideas?
    13,559
    What are the sensors doing on the scanner?
    Are they even functioning or showing any movement?
    The P0154 points to no activity, so there is a power/ground issue there. Check all fuses related to the o2 sensors. It will never enter closed loop if that sensor does not work.
    7,575
    Sep 2021
    8
    I will check for power when I get home, it?s got a Painless Swap Harness in it so there?s only 4 or 5 fuses on that harness.
    Advanced Tuner Shrek's Avatar
    Nov 2011
    753
    It is difficult to assist you, when you fail to post your current tune.
    Jan 2021
    29
    Run it open loop and set your EQ to 1 across the board
    Sep 2021
    8
    Quote Originally Posted by sayangetsome View Post
    I will post tune when I get it back together. It was a wire nightmare previous owner had extra wires tucked under the vortec cover and just a mess all n all. I pulled the whole harness putting the pcm inside the cab and will post tune and stuff when it?s back running in a day or so.
    Feb 2021
    2
    i would like to know what you fine
    Sep 2021
    10
    im curious too
