Results 1 to 3 of 3
Thread: spark table matching
    Aug 2021
    17
    can anyone tell me some more about matching {blending} the main spark tables with the idle spark tables the benefits and the drawbacks
    Advanced Tuner Matt Vardaman's Avatar
    Mar 2021
    207
    I Make the low octane, high octane (main spark), and In gear timing (base) tables match where the engine Idles. So that when the ecm changes from base spark (in gear throttle closed) to Main spark tables there won't be a sudden drop or spike in timing, which would cause hesitation or stalling. This only applies to .08 - .24 cyl airmass in the 400-800rpm columns in most street applications.
    2001 Silverado 5.3 - 209/217 cam, GT45 Turbo on 7lbs, Aem x-series wideband, 50lb/hr flex fuel injectors, on E85 with content sensor
    1999 Silverado 6.0/4L80E Summit Stage one camshaft, 317 heads (replaced cast iron)
    Aug 2021
    17
    that make sense thank you for the info
