Results 1 to 2 of 2
Thread: Getting rid of VVT.
    Sep 2011
    25
    Getting rid of VVT.
    I just swapped a 6.2 into a 14' Caprice roller. I converted the engine to a non DOD/VVT engine. I'm reusing the E38 PCM from the Escalade as my car didn't come with one. I know DOD I just turn off. What do I need to do to get rid of the VVT tuning? Can I simply go into the VVT tab and turn it to none for # of cams and zero out the other tabs. I compared it to a non VVT tune from another E38 pcm and that's all the non VVT car has is none and zero'd out VVT tables. The engine has a LS7 cam so its not anything crazy the stock tune can't handle.
    13,565
    Yes, change it to none and zero out those tables. Then turn off all the VVT codes.
