Results 1 to 10 of 10
Thread: how to tune F/A WITHOUT O B1S2 OR B2S2?
    Jan 2021
    Miami
    351
    Have no rear 02s just wb, help
    By the prickle of my thumb something wicked this way comes!2008 Chrysler 300c! 2013 heads/220/230 comp cam/LTheaders/FTI 2600 stall converter.
    Jan 2021
    Miami
    351
    the wide band is all over the place, idle 13.9-16 driving the same. dont know if the wb is working correctly of my tune needs more attention.
    Advanced Tuner coanan's Avatar
    Mar 2009
    S. Florida
    582
    Don't need rear O2s, they just report how cats are doing.
    Try another W/B sensor, mine was doing the same, replaced it and back to normal.
    2018 Trackhawk PCM/TCM tune by Dusterhoff.
    Flex Fuel, MMX faux 95mm TB, GripTec 2.85, 10% ATI lower, FIC1200, ARH 1 7/8 w/cats, 180 T-stat
    13 Chrysler 300S, RAM BGE 412 stroker, cam motion 232/246 619/619 118 +4, ATI 18% OD pulley
    Whipple Gen5 3.0, 2.50 upper pulley, Smooth Boost controller, FIC 1200 inj. Nick W 108mm TB, FORE dual return fuel system, E85, FTI 2800 stall(SRT83380), SHR WAR Viking trans and valve body, Getrag 3.73, 1 7/8 kooks w/hi-flow cats, 3" Magnaflow Cat-back 943rwhp
    Jan 2021
    Miami
    351
    ok cool just use the up 02's to populate the grafts? the WB is new, about 4months. ill return it and see what happens. thanks for the reply.
    Mar 2009
    S. Florida
    582
    Quote Originally Posted by Turbo2gnx View Post
    Just need the fronts for tuning. I had a PLX fail pretty quick. Too much wired in, so I just bought another sensor.
    Jan 2021
    Miami
    351
    ok cool, taking it out this weekend.
    Jan 2014
    SoCal
    1,562
    You don't have a log. That being said there is a normal oscillation of A/F in all vehicles that aids in "scrubbing" of cat converters. The more rapid the change in the switching point the better the cats will work.
    Jan 2021
    Miami
    351
    ok so this is normal, cool. do i need it to do this even if i removed the cats?
    Jan 2014
    SoCal
    1,562
    Really does not matter if it does not have cats. The rapid rich lean switching is done solely for cat function.
    Jan 2021
    Miami
    351
    how to get stft to -/+5 and a stable idle? thanks in advanced.
