Results 1 to 3 of 3
Thread: c10 ls swap
    Feb 2021
    2
    c10 ls swap
    whats up guys can someone please help
    ls swap gen 3 5.3 punched out to 5.7 , ls6 intake stock injectors, sloppy stage 2 cam , painless dbc harness
    will not go into close loop. .... and no i am getting maf code p0102, p0106, p0358
    log file
    13,578
    Kinda need working o2 sensors to get a working closed loop. The logs shows both sensors at 450mv, meaning you have a power/ground problem on. Check the fuses and harness to make sure they are getting power.
    The P0102 is a MAF circuit low code and the P0106 is also a range/circuit code. I've never used one those peoples wiring harness but I swear I see lots of posts going on with problems. Whether they are truly harness related or the users fault is hard to say sometimes.
    Feb 2020
    Bethpage, TN
    15
    Painless wiring is a pain in the.......
    I've had issues with Painless wiring harnesses before. 450mv at the sensor definitely says that the sensor is not reading. (PCM defaults to 450mv if the sensor is disconnected)
