If I set the upshift mph charts to zero at 80% and higher will the trans only use the rpm shift charts to shift ?? Or is it 256 ?? I thought 256 tells the computer to NOT do something.
yeah you'd need to set it to 0mph.
ok, so just to be sure, if i set 80% and higher cells to Zero for the upshift, the computer will only use WOT RPM as a shift point.Originally Posted by foff667
Do I need to set the down shift cells to 0 also ?
Thanks for your help.
What would be the purpose of having it shift at both mph and rpm? If this works let me know. I would like to set mine up like that as well.
99Z A4 w/ SS LT's, h/f cats, magnaflow catback, port/polish t/b, egr deleted, ls6 intake, lid, 3.73's, hpt, performabuilt level 1 tranny, 3600 stall, Stage 2.5 (5.3 heads), Torquer 2 cam, 42# reworked injectors, TR6 plugs.
2007 Avalanche LTZ - Catback and Eibach springs
Don't do it.Originally Posted by domestic rice
Russ Kemp
