Results 1 to 9 of 9
Thread: fuel trims not adjusting properly 6.4 hellcat supercharged
    Hey guys so doing part throttle and drivability tuning on my Scat pack and when changing the ve tables I am not seeing my changes reflecting in the tune at all same trims with each log even after adjustment. Car is a 2020 Scat pack running hellcat supercharger and injectors. It was pulling 15% at idle made the ve corrections and still pulling 15% has anyone seen anything like that? Best part is the wide band shows I am right at 14.3-13.5 at idle so its not as far off as the log shows. Mechanically its perfect, brand new injectors, plugs look absolutely perfect too. Could I be chasing my tail trying to get closer to 14.5 steady at idle? I attached my current file. Idle surges 50-75 rpm too so I was hoping getting the trims cleaned up could smooth that out a bit. I'm pulling my hair out at this point too because I have spent like 2 days on these trims.
    822
    post files
    file is in the post
    Mar 2020
    Waxahachie, TX
    47
    Quote Originally Posted by DefierPerformance View Post
    file is in the post
    Your post shows "attached files" but there is nothing there for us to download and look at. Can you reattach your tune and logs?
    822
    Your injector data looks wrong to me. Where did you get it?
    Nov 2009
    All Around
    3,149
    do you have hellcat injectors in the car?
    you also need to consider that hellcat injectors operate an different flow rate especially under wot compared to hemi 6.4
    Sep 2022
    Hello, I need a file for the Charger and Eddie I want to skatback 2020 in stock
    Would need to see a log of the issue first.
