Post #10 has every version of a P59 OS you'd want. You can segment swap in anything from 80e, flex, 3 bar SD, DBW or cable etc. I'm using this OS for 3 bar SD, flex, DBW and analog AC controls.
https://ls1tech.com/forums/pcm-diagn...-3bar-dbw.html
2001 Silverado 5.3 - 209/217 cam, GT45 Turbo on 7lbs, Aem x-series wideband, 50lb/hr flex fuel injectors, on E85 with content sensor
1999 Silverado 6.0/4L80E Summit Stage one camshaft, 317 heads (replaced cast iron)
