Results 1 to 15 of 15
Thread: IAC drops to zero. idle surges 3000+
    Sep 2019
    33
    hello everyone. i have a 1986 s10 that i swapped an lq4 that i got from a van. using the same ecu (p59). my truck started off with a powerglide and over the winter i swapped in a 4l80e with a Manuel valve body ( no electronics). while the truck had a the powerglide it ran well, after i finished the the 4l80e swap. my idle seems to rise up uncontrollably. there are no vac leaks no major mods other than 243 heads with aftermarket headers. the truck will idle okay if i unplug the iac at 250 count. i can place my finger in the iac port and choke the engine to stall out and still feel a vacuum on my finger with the engine off.
    my current tune is setup for tuning the VE i deleted the maf. i cleaned the iac. swapped another into it still does the same thing.
    i have 2 scanner recordings, 1 is with the iac plugged in and you will see the idle go up and down because of my finger in the iac port, the other one is with the iac un plugged
    idle with iac unplugged at count 250.hpl
    werid idle lq4.hpl
    4l80e open loop VE.hpt
    Sep 2019
    33
    please help
    Banned
    Oct 2016
    379
    In case this helps:
    "IAC Relearn Procedure
    If you are having idle issues you may need to reset your Idle Air Control (IAC) and TPS, do this before you start drilling holes in your throttle body (TB) blade. I have used this procedure on some huge cammed cars and it worked.
    1) Monitor your IAC, Idle Speed, throttle position voltage and your throttle position %.
    2) With the key in the ON position, adjust your TB set screw until your throttle position is 2%.
    3) Turn your key to the OFF position.
    4) Unplug your Throttle Position Sensor (TPS) and IAC.
    5) Turn your key to the ON position for a few seconds, and then OFF again.
    6) Plug in the TPS and IAC and then turn your key to the ON position and restart logging. Your throttle position will now be reset to 0 degrees and about .45-.55 volts.
    7) Start your engine, your IAC should be 40-60 for a cammed engine.
    If you are not at your desired IAC position, redo the above procedures in smaller increments."
    Sep 2019
    33
    okay will try. but my engine has a stock cam
    Sep 2019
    33
    hellllllpppppopppppp meeeeee
    7,649
    You have to get it back into a diagnosable condition first, after all your plugging-and-poking things at random. It's probably very confused now. Trying to pinpoint problems while it's in a mixed up state is only going to lead to more confusion no matter how much you whine about not wanting to do the reset procedure.
    Sep 2019
    33
    okay ill try what mr smith said
    Sep 2019
    33
    Quote Originally Posted by Mr. Smith View Post
    In case this helps:
    i tired it and still nothing. my tps voltage is at .76 at 0
    Sep 2019
    33
    can somebody please check my tune and scanner recording ??
    Sep 2019
    33
    thanks everyone
    Mar 2011
    Ripley, MS
    1,865
    It certainly could be a faulty IAC. It's got to be getting air from somewhere.
    What DTC's do you have? Be sure to disable all of the transmission related DTC's.
    Sep 2019
    33
    do i set the codes to first error or no error reported to delete it. because for the maf i did mil on first error
    Sep 2019
    33
    the only dtcs i have are maf and tranny ones
    Banned
    Oct 2016
    379
    Quote Originally Posted by perrone123 View Post
    Try again/harder. Adjust the throtte (body) stop screw until you get 0.5v at idle and around 4.5v at WOT.
    It might not solve your issue but do it anyway. That's ^ idle and IAC basics.
    Sep 2019
    33
    i got .5v at ilde and 4.5 at wot still the engine wants to rise up. i changed the intake manifold gasket. im at a loss please can someone check my tune and recordings.
