Results 1 to 7 of 7
Thread: aem 30-0310 CAN prolink
    I should be able to hook the can lines from controller to prolink can correct? I cannot get it to display properly when connected this way. I can do analog and get a reading to display but math doesnt seem correct. I have them grounded together the pro link and aem. Am I missing something
    So is the can out of aem not able to be read by the can wires on the prolink?
    Mar 2020
    380
    I use the Analog
    Brown -
    White +
    Dec 2005
    604
    You should be able to connect the CANH and CANL wires from the 30-0310 to the ProLink. And read the AFR/Lambda signal, directly. I have done 4 at once, this way.
    must you have pro link to use the can feature? at first i thought it was can ready to just tie into the canh canl but now i think it has to be flashed ? is there a place i can wire it in to act as another ecu of some sort?
    Aug 2014
    Central, LA
    737
    Quote Originally Posted by dr.mike View Post
    Have you used it on a very recent (as of 10/7/2021 at least) version of the scanner? Mine dropped out, and I upgraded my interface to try to resolve it and it will not work. Analog is fine.
    Mar 2020
    Western Canada
    91
    Analog works fine
    Its the can that is inop
