Thanks for the reply guys!
Just to clarify - this is a towing rig that regularly pulls 8k+ lb trailers. The truck's curb weight is 6400lbs.
With the priority being component protection, wouldn't a 12.0:1 AFR target be a little lean for this kind of load? Especially for regular pump gas?
You'll love this extreme example: a stock Dodge 5.7 charger PPV targets the low 9s
(0.637λ with a 14.534 stoich = 9.258:1)
Dodge generally targets the mid to low 11s in their 5.7 trucks during PE.
So why would they choose to run the PPV so rich?
If the answer is component protection, why wouldn't the low 10s do?
("Weak pistons" and "dodge is dumb" aren't good answers
Their gen3s use modern hypereutectic alloy pistons like every other manufacturer, but the 5.7s lacks piston oil cooling jets - could that perhaps be a factor?
