Ok , here it goes... My scanner is not populating the EQ error histogram. nor the AFR error Histogram.( I'm trying everything here).
I have a lc-1 wb, My map sensor I believe to be a 2.5 Bar sensor.
My channels reflect a 3 bar MAP, EQ Ratio Commanded , AFR Ratio Commanded, RPM, MPVI2.1 Innovate-LC-1, MPVI PL A/D Input 2 (Blue)
I am really Freaking lost here.
Had it working with AFR error logging a 1 bar map but it topped out at 105Kpa.
Do I need to rescale something in the scanner to log the 2.5? there is no pid for this.
At this point I will use AFR or Lambda, I really just need somethin that works.
HELP!
