Results 1 to 3 of 3
Thread: No start, E38 pcm swap
    Sep 2011
    25
    I have a 2014 Caprice that I did a 6.2 swap into. The car was a roller and ended up using the PCM from the Escalade the 6.2 came from as the car didn?t have one. As of now, I?m getting a service anti theft message and have a no crank issue. Once I flash the PCM with the correct vin, would that fix the issue or will I have to change something else in the PCM?
    13,576
    The VIN doesn't really matter for it to start. The VATS and the starter fault have to be disabled with a write entire for those problems to go away.
    If you want the engine and transmission to jive together though, you will need the PCM and TCM flashed together with a VIN/OS that match if you are using an automatic transmission.
    Sep 2011
    25
    I can flash them myself in the OS tab right?
