I have a turbo gto with the e40 and dpe 2.5 bar map. My question is what happens if I excede the 255 e40 hard code limit. Will it carry over that cell or freaking explode?
cam only 136k plus mile ls2 longblock supercharged gto 11.1@126 1/4 mile on 8psi
Usually it's a giant ball of flames.
The computer will just use the last value in the MAP when you go over it. Just like with timing, if you go past the 1.20 cylinder airmass it just keeps using that last value.
That's what I figured, I just wanted to be sure. Thank you
